![]() | Home > eBay & Bargain Spots > Feeling a little low? NEW Battery required? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I have got to share this with you |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
bump............as peeps are missing this and wasting lots of dosh |
If you have used this site, like me and have found the service excelent, add a comment so that it remains near the top for others who might be suffering |
No nothing required other than a 10mm spanner, and a screwdriver to get the bonnet in to service mode.. it's the 2011 on that require programming |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Perfect! Plenty of pennies saved on what I was going to spend... |
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
I fitted the 020 varta battery on my 08 TDV8 as per Miggit's recommendation recently.
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Hi Miggit, not that I need to change my battery yet, but is that right, programming is needed to change the battery in my 2011 Vogue? What does it entail, need to got to Landrover dealer.? |
Hi ya buddy, still going everywhere in reverse at night? |
Great explanation as usual, reversing lights still doing the business |
I'm trying to get the definitive answer regarding resetting the ECU, I will let you know when I do |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Sorry to resurrect an old thread, but can anybody point me to the settings for the IID tool to reset the battery charge mode.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
it should be in the BCM menu... ... - .- -.
Many thanks Stan, I have seen the battery entries in the BCM menu, but that appears to be the type of battery i.e. H8 90Ah 800A. This does not appear to be a battery monitor reset value.
