![]() | Home > Maintenance & Mods (L322) > |Replacement battery for the 4.4 tdv8. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
https://www.tayna.co.uk/G14-Varta-Start-St...P8424.html
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I don't think that you need top reprogram if your do a like for like swap...........
YES |
There is something there. It tends to be the explosive charge which gets in the way. Managed to get an 020 into the old car with a bit of faffing about. There is nothing that can't be fixed with a hammer😜😜
I had no fitment issues with the bolt on bomb... but then i was fitting a Varta battery (OEM) so i wouldn't expect there to be any probs. I only posted the last link cos the OP was having grief getting at the battery in the first place... It would appear that stuffing the battery under the windscreen didn't generate quite as much work as Land Rover had intended, so they decided to bolt a few extras in the way |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 840 ![]() ![]() |
I think a reprogram is still necessary. It's because the intelligent battery monitor will have been monitoring the falling performance of the old battery, and the charging will be optimised for an old knackered battery.
I think that I've read that the IID Tool covers this |
I think I need to get me one !
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
here you go ..........................https://www.gap-diagnostic.com/products/iidtool/ |
http://www.island-4x4.co.uk/integrated-int...27303.html
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
our site sponsor dan@duckworths sells them.. |
