Home > Maintenance & Mods (L322) > Tdv8 4.4 oil
Dogfishdave
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Tdv8 4.4 oil
Hi all, just a quick question. How much oil do you use between services ? Say 5/600 miles.
Thanks Dave
Post #413017 10th Nov 2016 10:38pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Never used any in 55k miles between services
Post #413027 10th Nov 2016 11:23pm
Mine uses a drop or 2 about 1/2 a litre in 10,000.
Remember to check the level with the engine up to temperature, then give it 10 mins for the level to settle before using the electronic gauge. My level indicator tends to creep up too so give it a minute to register before adding any more oil. There is nothing that can't be fixed with a hammer😜😜
Post #413099 11th Nov 2016 5:19pm
pld118
I can't seem to make our electrnic gauge work/ must be doing something wrong!
Banging Head
Post #413113 11th Nov 2016 6:29pm
Baltic Blue
Engine has to be off for minimum of 30 minutes before it will work.
Post #413115 11th Nov 2016 6:32pm
ignition on only, no engine start... Wink ... - .- -.
Post #413124 11th Nov 2016 6:46pm
^wot he said, though I find 15 mins is usually sufficient. Thumbs Up
Ignition on, service menu, oil level. There is nothing that can't be fixed with a hammer😜😜
Post #413127 11th Nov 2016 7:12pm
