![]() | Home > Technical (L322) > Popping and crackling sound |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3280 ![]() ![]() ![]() |
Check the wiring is properly connected to the speakers in the doors. Sometimes they can be broken off or loose. Also check for corrosion on the spikes/tongues on the plugs into the amp. Sometime a toothbrush and bit of electrical contact spray can work wonders. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
Could it also be external interference? Does it happen anywhere or just somewhere? I get similar symptoms when driving in one particular area. 405 AB exec seats Baltic and Cirrus
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Thanks for the replies:
Paddyc Member Since: 31 May 2016 Location: Antrim Posts: 13 ![]() ![]() ![]() |
hi stormin
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 ![]() ![]() ![]() |
Strong chance it is the tailgate seal letting in water....thats what mine was doing.
Closerthanmost Member Since: 27 Aug 2017 Location: Cambridgeshire Posts: 62 ![]() ![]() |
This has just happened to mine too.
Thanks cooper- going to give mine a really close inspection this weekend
The tailgate seal is notorious for letting in water and dumping it over the I.C.E and Nav equipment in the boot, mine filled up the cubby hole with about 3" of water before it all went POP |
No worries Paddy. |
