Home > Wheels & Tyres > wheel nuts
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
wheel nuts
hi recently bought a set of newer alloys from a member
my old alloys are
will I need to get new nuts cheers in advance
Post #413212 12th Nov 2016 2:12pm
sam919
With limited knowledge, I just bought some 19.6/20mm shaft diameter nuts for an earlier set of 18"s, if you measure the internal diameter of the stud hole , this will tell you what size you need. FYI my other nuts!, had a larger diameter so didn't fit the holes.....so your newer wheels are likely to have these larger nuts.
Post #413213 12th Nov 2016 2:25pm
you need the type on the right for your new wheels,
Post #413216 12th Nov 2016 3:15pm
builder1966
cheers stan found a company local and cheap too ta
Post #413228 12th Nov 2016 5:14pm
