![]() | Home > Wheels & Tyres > air jack |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/4t-ton-Exhaust-J...Sw4GVYHNCQ has anyone tried one of these just wondering if would be ok to use if needed to change wheels ??? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
In a word NO |
had one years ago on a series 2a worked great is there a major problem with just connecting to one exhaust ? |
Only in as much as the system is not a true twin system, and the rear box has 2 pipes.. as the air bag needs pressure to inflate it, and one side of the box is open, there was a though "is there enough pressure" from what will effectively be a leaking exhaust... and then there is still the issue of getting at the bloody pipe to start with.. they have sort of hidden it up behind the rear wheel, |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
I have one but I wouldn't use it to change a wheel. It's a recovery device when one is bogged. But as said above, the twin exhaust outlet could be an issue. I haven't tried it with the L322. Ron B. VK2OTC
ok cheers think il get one and try it and report back I can always use it on another motor or as afloatation aid in one of my boats |
Many many years ago someone here was going to experiment with lifting bags and using a plumbers pipe bung cut down to close off one of the pipes but I don't remember the outcome if any . 2008 MY Supercharged
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
We used to jam a potato into exhaust pipes for other reasons when I was a kid |
