Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 17 of 22 <123 ... 161718 ... 202122>
dognero
England 2008 Range Rover Vogue SE TDV8 Santorini Black
New kit came today.
Fitted 2 in each.
Just put the lenses in hot water for 10 min to part them.
Very easy job.
Daylight
19.45
[/img]
Post #410805 26th Oct 2016 7:52pm
Bluegreygreen Rangie
Australia
They look pretty darn good
Has anyone seen or used these http://www.ebay.com.au/itm/360944738589?ul_noapp=true
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #413227 12th Nov 2016 5:14pm
craig had these in a couple of his chariots... ... - .- -.
Post #413232 12th Nov 2016 5:31pm
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Dave
I've fitted these and the reversing lightt output is very good and a great improvement on standard output
Mine also flash in time with the indicators but led red - a bit to policey (?) but have been through 2 MOTs with no issues
Post #413288 12th Nov 2016 11:19pm
miggit
^^ Whistle A box of matches is an improvement on standard Wink
The only car that I have owned that has worse reversing lights is my Austin Seven Saloon... and that is probably because they didn't fit them to the Mini until the 70's and mines a 1959 Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #413291 12th Nov 2016 11:47pm
Rob99
Anyone know whether you can buy reversing lamps which have already been converted?
Although I am pretty handy with stuff I just don't have the time to take them off and do them myself at the moment and I use mine everyday so can't have it off the road.
Very Happy 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #413359 13th Nov 2016 10:46am
miggit
I have only ever seen one set for sale that weren't attached to a car. No one is producing them as the ffrr isn't a high volume car, so the only lights that are available to convert are OEM... with the LR price tag Shocked
I was thinking of doing something like that on an exchange basis, but, as the lights get brittle the older they are + one mans good is another mans sub standard, I decided that it was way too complicated unless new lights were used.. and that in turn loaded the price to start with to a point that I thought no one would be interested. And then there was another discovery made, the LED's function fine on an early ffrr's but, on the later cars, they can't handle the slightly higher voltage the AGM system runs at.... and they sort of get hot...DAM HOT Shocked and fail Big Cry
I did develope a way around this but it all adds to the cost.... Yesterday I couldn't spell Engineer... Today I are one!
Post #413366 13th Nov 2016 11:36am
it would be a seller if someone [in china?] produced a led equivalent ... even a slightly smaller unit would look nice .. ... - .- -.
Post #413400 13th Nov 2016 4:44pm
Australia
Dave
Interesting, Thank you. Not sure im too keen on them flashing red. Be great if they made them just with white led for reverse 2010 TDV8 Autobiography
GAP Diagnostics
Post #413401 13th Nov 2016 5:13pm
babagee
I would have thought it would be simple to connect up just the reversing lights and stop lights leaving the indicators not connected
Post #413407 13th Nov 2016 6:39pm
miggit
^^ If your fitting those, don't forget to add Red Reflectors to keep on the right side of the law Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #413426 13th Nov 2016 9:18pm
rar110
Do these flash as the car sends a test pulse around the car to locate dud incandescent bulbs? ______________________________
Post #416723 5th Dec 2016 12:21pm
miggit
Rolling Eyes they shouldn't, but it really depends on what you wire them to, the reverse lights are not monitored by the LCM Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #416745 5th Dec 2016 2:54pm
rar110
Thanks miggit. I assume the LCM sends a pulse to the brake light? And that without without a diode will flash like my LED trailer lights? ______________________________
Post #416840 6th Dec 2016 10:08am
miggit
Yes Bud, the LCM, or Light Control Module, repeatedly sends very short pluses to the lights to make sure that the circuit is still working correctly, i.e. the bulb is still functioning and there isn't an open circuit... which would indicated that there was either a broken or missing bulb. When it does this a normal filament bulb is too slow to light up, and it will appear to be off, when a LED is introduced in to this circuit it flashes because the LED reacts much quicker.
I suppose that the addition of a capacitor in to the circuit might stop the blinks, but I don't think that a diode will stop the flashing, the best way is to turn off the LCM for that circuit with either a Gap IID Tool of NavCoder Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #417111 8th Dec 2016 12:05pm
