Home > Technical (L322) > Correct engine oil 2007 tdv8
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
What is the correct engine oil for a 2007 tdv8 vogue se
What does everyone here use different searchs bring up different oils
The filler says Castrol but which one A friend told me use magnatec 5/30 when looking there are several A1 A5 c etc
Thanks in advance
Post #413617 14th Nov 2016 10:26pm
The correct oil is one which complies with the ford spec for the tdv8 which is
Wss-m2c913-b it will say on the tub what specs a particular oil meets. There is a magnatec which meets the standard also there are she'll heilix oils which do too. There is nothing that can't be fixed with a hammer😜😜
Post #413626 14th Nov 2016 10:47pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I bought this: http://www.ebay.co.uk/p/exol-optima-fd-5w3...7675.l2644
After a forum member recommended it. Approved to WSS-M2C 913-D
Seems fine.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #413627 14th Nov 2016 10:55pm
