![]() | Home > Technical (L322) > Suspension leveling |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Hi all,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Standard height settings are 493mm front and 483mm rear
So what do I have to do now to reset it back to default.
Hi Joe,
If I press the level button the FF lowers to standard height and the display says standard.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Before I attempted to level the suspension it worked 100% without fail. I have a feeling it's to high, when I press up the body lifts and continues to lift until the message shows.
I levelled the FF last night and the below pic shows the info but I can't use the up or down as I used to.
I know the sites been down but does anyone have a clue how I can reset the suspension back to how it was. Range Rover quotes.....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
on activation the iidtool saves all the settings so go into the restore menu and it will all go back .. ... - .- -.
Your a star, trying now. Range Rover quotes.....
I can remember seeing that option and it didn't work but tried it again and it seams to be working as normal.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Why 06 s dont show highway mode?
a 2006 FF goes down to highway [motorway] mode at 100 mph and not 60mph'ish as on the earlier FF's.. ... - .- -.
