Home > Maintenance & Mods (L322) > 2003 L322 TD6 Air Con Rad Replace
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
What an easy job that was !
Remove viscous fan and rad cowling
De-gas system if any gas left in by means of air con specialist
Undo 2 x AC pipes from AC rad
Remove 1 torx screw from below the the 2 AC pipes
Remove 2 plastic "bolts" from slam panel that support the rad assembly
pull rad assembly towards engine and remove the 2 x plastic corner section from corner of rad assembly
Slide out AC rad
Fit new AC rad and refit all the above
Re-gas AC
I got the AC condensor/rad off The Bay of E for £55 delivered (UK) 2009 - L322 5.0 S/C Autobiography
Post #413838 15th Nov 2016 10:29pm
i did a replacement on my td6 so it must be easy.. Mr. Green ... - .- -.
Post #413843 15th Nov 2016 10:51pm
