![]() | Home > General (L405) > well the bubble has burst (fixed) |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 143 ![]() ![]() ![]() |
My first problem after 11 months of trouble free driving the car has let me down - neither of the smart keys are working |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 ![]() ![]() ![]() |
Call out LR assistance |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
+1 LR Assistance has to be the way to go |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
Why should they charge you for investigation if it's only a year old? Agueroooooooooo. 93-20
Now you mention it mine was in for 1st service 3 weeks ago and the dealer asked for both keys to do an update. Agueroooooooooo. 93-20
just discovered I can lock it with the skeleton key , don't know why I didn't try that earlier must be an age thing |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1172 ![]() ![]() ![]() |
Good question, why? |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
The update is to replace the Key Validation Module so that it is now read-only so that anyone breaking into the car cannot then create a new key from the OBD port. That is why both keys are needed because they have to be matched to the KVM |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
How far back does it go please? |
visited Stratstone Aylesbury yesterday
Not heard of that one.
think I shall try restoring default settings on sat nav to see if that sorts it
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I've accidentally turned my Sat Nav volume down several times now - if you happen to alter your music volume as the Sat Nav says something, you end up turning that volume level down instead. Easiest way to get it back, assuming you have a destination set, is to go onto the Sat Nav map and touch the speaker looking icon at the top of the screen towards the right to make the Sat Nav repeat its last directions and as you do this, turn up the volume knob to the preferred level. If the voice ends and still isn't loud enough, just repeat it (I find it easier than guessing what level to set it at in the audio volume setup menu). Steve
