![]() | Home > Technical (L322) > Suspension leveling |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
it seems the 2006-2009 suspensions are setup to ride adequately at standard mode up to 100mph.. ... - .- -.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3950 ![]() ![]() ![]() |
Just back to the original post - I did have this message because I'd used the IDTool to set "tight tolerance" or "workshop tolerance" or something like that whilst I messed with suspension heights. I did not set it back to normal so compressor worked overtime trying to keep the car very level rather than just fairly level if that makes sense. Anyway it got hot, things slowed down and started misbehaving but when I did eventually realise my mistake and set it back to normal tolerances the problem went away for good. Geoff |
