![]() | Home > Maintenance & Mods (L322) > Tuning Box for 3.6 TDV8 Good or Bad |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I personally would not use a tuning box. I don't understand how it can do anything other than fool the car into pumping more fuel into the engine, which without a corresponding increase in air flow, simply results in overfuelling
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Had a couple they are a short cut but to contradict GraemeC MPG went up.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Is that the Pro Bitz one, Andy? John
Not sure now Weegie it was about £80 I think they all work in a similar way by increasing the fuel pressure in the rail.
My gearbox has failed but that seems to be standard on the TD6
Thanks for that. |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
ii had a probitz on my 03 td6 and it was great, clocked 40k with it no issues at all made it go like a bullet from standstill and no lag or thinking time to pull out, made the mid range more responsive and would use again if i had one tbh, looked at a lot of suppliers before probitz and found it to be best for me |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
Thanks Gents,
This is interesting to read if you have the time
