![]() | Home > Technical (L322) > Umstable at high speed braking. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Could be a number of things. I would look at sticking caliper then roll bar drop links for starters. John
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
It might be worth feeling the temperature of the wheels after some driving, Like Weegie pointed out a caliper could be binding or a wheel bearing tight etc however if so that particular wheel will be hotter to touch than the others
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I had this and it was two things! First sticky rear caliper and the rear anti roll bar drop links needed replacing! So exactly as the previous posters said!
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
It could be tracking or worn joints, is check the upper and lower joints on the rear in particular. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
