![]() | Home > Technical (L322) > TD6 over cooling mystery! |
sarn Member Since: 05 Apr 2013 Location: Oswestry,Shropshire Posts: 27 ![]() ![]() ![]() |
Am definitely going to try running TD6 minus viscous fan just in case this is at fault. Have been meaning to do this for ages but only now the cold weather has arrived,it's become urgent! |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
You can hear the fan if you know what your listening for when it is running / driving, they are very noisy!
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 ![]() ![]() ![]() |
Thanks for the reply miggit. However there is a bleed screw that's higher in the system than the EGR cooler supply and return (see photo)[img]
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
My only thoughts are they've fitted the bleed screws at known airlock points in the system.. and you have done away with one.. it could just be there because the EGR cooler gets airlocked, but it could be more than that... the main bit of good news is that it isn't overheating, so it is useable |
Two week gap and about a thousand miles. I have no loss of fluid (good) but the temperature gauge is cold going downhill and warms up towards but never reaches the 12 position under uphill load. I think it might be time to change the main thermostat and I think the Gates one looks like the best option. I'll update here when I get it done. |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 ![]() ![]() ![]() |
Hi guys, my TD6 is also running cold! sits constantly at 10 o'clock with very small fluctuations up or down, it did once cool down to the top of the blue section too! |
Hi Ollie7195. I removed the complete EGR system about a month or so ago. The original advice was on the Aussie RR site at http://www.aulro.com/afvb/l322-range-rover...tem-2.html
Hi mariner30! I've got the blanking kit with the exhaust manifold blank as I was planning on removing the egr completely at some point but didn't know what size the pipe diameter was for a plug (guessing around 15mm inside diameter?) and didn't want to drain it down as I need the car during the week, but thanks for the tip |
The LR Thermostat is LPEL000050 and retails from LR at £69.06 inc VAT. The blanking caps are 16mm and come as a pair. The water pump should be changed while you're there unless it has already been changed. The new one will have a metal (not plastic) impeller)
Thanks for all that, greatly appreciated! I have no excuse not to carry on with it now |
Just tested the viscous fan and it appears to be sticking, I don't want to use the word cease as it can be spun by hand when the engine is off but it stops after about half a turn, but tested with the news paper and the fan showed no signs of stopping so that will be coming off and going in the bin! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
^^^^ and leave it off |
Probably right Joe 90. Just travelled about 160 miles on Motorway and country roads. Temp remained steady at 12 o'clock all the way. Time to remove the fan when I get home next week, methinks.
Finally got round to removing it all! changed the main thermostat, annoyingly the original was still holding fine when i tested it, but the water pump was the original and it was just beginning to get a bit of slack in the shaft, blanked the EGR at the exhaust manifold and boy what a difference!
