![]() | Home > Technical (L322) > Compressor or EPB fault ? |
did you touch the wheel to see if it was hot [sticking caliper] ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Sounds like a sticky calliper to me.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Right hand side wheel hot, near side cold.
Strip the brake down and check the pads aren't stuck first. If they are a PItA to get out then the carrier is corroded. It's generally only surface rust and a good clean up may sort it before you invest in a new calliper. There is nothing that can't be fixed with a hammer😜😜
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Doesn't the EPB engage automatically after ignition off anyway so could it be that after all? 405 AB exec seats Baltic and Cirrus
