Home > Technical (L322) > Stainless exhaust for L322 TDV8?
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Thanks for the hartge idea but I think that's a bit beyond my finances!
I messaged the ebay seller of the Direnza system, saying:
Hello,
I'm interested in this system but can you confirm it is genuine Direnza? It is £200 cheaper than from their website and you have listed it for V8 diesel models where as they list it for 2002-12 V8 petrol (I need it for a V8 petrol).
Thanks,
Matt
They replied with:
Hi there,
Yes they are genuine direnza parts and there are for the v8 vogue,
Kind regards
So, based on that I think I will pull the trigger on it, as if they turn out not to work then I have them over a barrel for evidence. NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #414147 17th Nov 2016 8:18pm
alistairh
Keep us posted on your findings Thumbs Up
Post #414150 17th Nov 2016 8:27pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
just find an independant exhaust maker they are usually found in performance car garages although some tyre places will have someone who can custom make one for you L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #414193 18th Nov 2016 8:50am
Bluegreygreen Rangie
Australia
Im going to have the cats and whatever the first small muffler is not far after them (My car does not have DPF's) removed from my 2010 TDV8, I am chasing better flow and some more exhaust note as you are
When i do ill let you know my findings
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #414242 18th Nov 2016 2:49pm
mat777
Ordinarily I would just remove my cats altogether, but the new MOT rules over here prevent that now Evil or Very Mad
You're lucky you're in Aus! NW060
Post #414429 19th Nov 2016 9:04pm
Ivor
depending on how handy you are with spanners you could always get the cats cut out and flanges welded and also have two straight through pipes made so come MOT time you swap them over or just replace them with a 200 cell cats L322 2008 vogue
Post #414462 19th Nov 2016 11:14pm
mat777
Well, it's arrived and it's good news. Yes, it does look exactly like the pictures on the Direnza site. and yes it does have a cat inside it when I checked with a torch.
Now to get it fitted when I'm home from uni for the winter! ON the subject of which, they appear to be handed - the front lambda sensor port is further around the tube on one side, and the trail ends are cranked by different amounts. I presume it will be obvious by inspection which side fits which? NW060
Post #414648 21st Nov 2016 2:11pm
mat777
Ok, having finally had them fitted before the MOT on Wednesday, it appears that there are a few slight issues.
Number one, replacement lambda sensors will almost certainly be needed. Their thread sticks down into the exhaust flow causing the end few turns to fur up with rust, meaning they simply won't come out of the old pipe without destroying them. the magician mechanic at my garage managed to save 3 out of 4 but had to give up on one. Bosch replacements are £70 each......
Number two - the new pipe is a different, slightly larger diameter to the existing pipe, and the clamps are larger again! They absolutely will NOT seal. The garage had to order in 2 different clamps, and due to the different pipe diameters it is still a bit of a fudge that involves a lot of exhaust sealant.
It blows a little when cold from the joint but after 2 minutes or so seals ok, and once warm and sealed the silence is uncanny after being used to the faint phut-phut of the cracked old cats.
On a positive note, the mechanic did say that the cats themselves look to be extremely good and very well made.
I think that if it doesnt coke up and seal the joint when cold, i may get an adaptor piece fabbed up, but other than that I suppose I can't grumble for £200 quid net (ie once the scrap price the old ones should fetch has been factored in) NW060
Post #419511 24th Dec 2016 11:40pm
alistairh
We had no luck fitting my friends either..if you find a solution to sealing the joints up properly please share Thumbs Up ..one thing to note with the system it sounds amazing...
Post #419538 25th Dec 2016 1:50pm
miggit
These might do the job... Commercial flexi exhaust clamps... they are designed to seal up on 2 different size pipes, I'm fairly sure that TTC (Truck and Trailer Commercial) do them, and most truck spares places deal with them Thumbs Up
 Yesterday I couldn't spell Engineer... Today I are one!
Post #419592 26th Dec 2016 12:16am
alistairh
Good shout buddy..i will hunt some down..if it works im going to purchase a direnza setup myself...
Post #419627 26th Dec 2016 1:30pm
