![]() | Home > Maintenance & Mods (L322) > 4.2SC 10% pulley |
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 ![]() ![]() ![]() |
Just finished up installing a 10% pulley. Initial impressions are like everyone else - feels smoother/lighter/less sluggish. Never really though I could describe this vehicle as sluggish |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 ![]() ![]() ![]() |
Was it difficult to fit? Did you just buy the bigger pulley or the whole snout with the pulley fitted?
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
Kyle can i assume that it was the 10% reduction pulley - who did it for you. Did you have it remapped; who did the remap? Please let us know about the numbers i.e. 0-60mph, power, torque, etc. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
Riedland Member Since: 06 Oct 2015 Location: Far east Posts: 21 ![]() ![]() ![]() |
According to Ebay's selllers you're right : "This ad is for a 10% uprated supercharger pulley for the supercharged 4.2 V8 Range Rover Sport. These pulleys are CNC machined, and produced to the highest dimensional tolerances and surface finish standard of any on the market, and made from high grade stainless steel which retains its superb finish after heating and fitting, unlike far cheaper mild steel items. Supercharger pulley upgrades are not only the most proven, but the best value performance enhancements available for your Jaguar supercharged engine in terms of £/bhp - by a country mile! Changing the pulley ratio results in the supercharger working at a higher speed and producing more boost. Because this just directly increases airflow through the car’s existing sensors, the ECU is kept aware of the increased flow and no further alterations or remapping are necessary. Boost & Power Increase - This modification gives a 10% supercharger driven speed increase, which equates to about a 2.5psi boost pressure increase (this is the pulley size which requires material removal from the supercharger nose, please see our other ads if you prefer the simpler job of fitting the 6% pulley option). These upgrades have been fitted now to many cars and discussion on forums and bar stools usually refer to a 35-40bhp gain from this size of pulley modification. That is true for the midrange gain, though the Eaton M112 supercharger becomes less efficient at high rpm so actual peak power gain may realistically be about 10bhp. Irrespective of the increase tailing off a little towards redline, this modification gives a HUGE increase in instant grunt and acceleration which really does transform the car. In some cases, belt slippage has been reported when using smaller upper pulleys but this is attributable to some manufacturers taking a cheap route and using aluminium alloy, which loses friction when hot, to make the pulleys. Our high grade stainless steel pulleys do not suffer from this problem." Current: - L322 2006 S/C lpg - RRC 1988 lpg / 287 000 miles - Stage one 1981 - Lightweight 1976 - 109 SW 1968 under rebuilt Gone: none |
This is a wealth of info on the subject:
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
My 4.2 has had the 10% pulley mod, coupled to a remap and improved air filter, for 3 years and I wholeheartedly recommend it.
I fitteded myself over the course of 4 days including waiting for parts and installing a new main drive belt and idler/tensioner pulleys. However the main drive stuff took less than 60 minutes after exposing everything that far. The fan + fan shroud was the most annoying to remove. You'll have to manipulate the upper AC line or remove it like the manual states. The pulley puller I bought required me to remove the odd jaguar water outlet/thermostat housing - so I needed some suppose seals that took me a day to track down due to doing it over the weekend. I bought the pulley on eBay for pretty cheap, someone else that bought but never installed. I 'rented' the snout machining tool from eBay as well for ~$50 US, the seller was 'local' to my area of the US.
Kyle,
Ok, i got the pictures organized better now. I had originally uploaded them with my phone. Tried rotating some of them but gave up.
Jcmitch3 Member Since: 01 Jun 2016 Location: Milford, PA Posts: 1 ![]() ![]() ![]() |
Would love more info on the tool used for the milling..... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
I've read somewhere that when you change the pulley on the SC and get towards the top of the power band the Supercharger is at it's peak before you get to full rpm, if you go a bit above it you do loose a bit of boost so that could be your problem.
Machining tool I used was this one:
