Home > Maintenance & Mods (L322) > TD6 alternator removal
Andy
Hi gang
Anyone replaced a TD6 alternator and if so, how did you get on with it? I'm just about to do mine and it looks a pig to do. I can't even get a socket on the bolts as the belts and pulleys seem to be in the way.
I've looked in the wiki but can't see a topic on it.
TIA
Post #414900 23rd Nov 2016 12:18pm
found via search,
http://www.fullfatrr.com/forum/topic28003.html ... - .- -.
Post #414902 23rd Nov 2016 12:22pm
Andy
Cheers Stan. It doesn't look an easy job as I suspected. And it's raining here...
Post #414903 23rd Nov 2016 12:29pm
Andy
All done. I took the radiator out in the end which made access very easy and no need to remove the power steering pump either.
As I've taken the rad out I'm gonna get it pressure tested as I'm losing coolant over time so I suspect there's a pin hole somewhere
Post #415414 26th Nov 2016 8:15am
