Home > Maintenance & Mods (L322) > RestorFX
Markjohns1
RestorFX
Hi getting a few scuffs an scratches sorted at a local body shop including tail gate and rear wheel arches. Car being java black quite a few blemishes swirl marks and scratches around the car and the chap suggested that he could remove all of these whilst sorting out the body work.He wants to use a correction system called restore FX.Anyone any experience of this product ?All comments apptecistef been told car will look like new.Wants £400 for applying this product. My concerns are will it last,does it work,can i still apply wax ,polishers and sealants agfterwards,does it effect the car paint work in any way? Full fat 4.2 Sc
Full fat vogue 4.4 petrol
Jaguar XJR super charged
Porsche cayenne
Tvr tuscan mk1
Bmw mini cooper
Post #415140 24th Nov 2016 3:58pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
Shocked googled it it says its hair restorer!!!!!!!!!!!!!!
Post #415142 24th Nov 2016 4:31pm
Sounds a bit expensive to me, there are no products they can put on the paintwork to make it stronger and shrug off scratches or swirl marks....
There are lots of products out there that claim this and that but none of them will beat the old fashioned way of polishing out the marks and using a good quality polish on the paint..
They can remove all the marks with a MOP (machine operated polisher) and proprietary products like G3 G7 anti swirl polish, hand finish, the list goes on, this would take a couple of hours to do the whole FF and about a tenner in products...
Just ask them how much it would cost to MOP the whole FF and then polish it yourself... Thumbs Up Thumbs Up Pete
Post #415143 24th Nov 2016 4:49pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Buy a machine polisher plus the kit for way less. It's one of the simplest and most satisfying jobs you can do. Thumbs Up
Pete, depending on the state of the swirls marks, takes way more than 2 hours, search an old thread I did on my old one.
Here you go : http://www.fullfatrr.com/forum/topic13701....rks+mr+tee
Post #415152 24th Nov 2016 5:28pm
mzplcg
Like Mr Tee says, DIY. Anything someone puts on the paint will only ever mask the damage. If you want it gone for good you need to machine polish the pain.
An example of how machine polishing removes swirls here. One half done, the other half as it came into me. (Customer's car)
This was the finished car
Post #415167 24th Nov 2016 6:39pm
You do know they have a speed switch.... Whistle I've done countless cars and never taken longer than 2 hours, I suppose if you haven't done many it will take longer...
This took about 2 hours including flatting, I didn't do the roof or boot though...
BEFORE
Flatted the whole car down with 2500 wet and dry....
Then out with the polisher, some G3, a wash and some Meguiars....
[URL=]
[/URL]
Thumbs Up :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #415192 24th Nov 2016 8:41pm
alistairh
That's amazing..i was ready to pay someone to touch up mine...what products do you need Pete? Pretty keen to give this a wee bash..
Post #415194 24th Nov 2016 8:44pm
mzplcg
Makita 9237CB.
Menzerna or meguiars pads and compound.
Microfibre cloths, plenty of them.
A tin of wax.
Masking tape for the trims.
Post #415213 24th Nov 2016 10:20pm
jonnyboy54321
Nice work there chap. 2007 Vogue TDV8 with 255/55/20's fitted
Post #415216 24th Nov 2016 10:38pm
alistairh
Great! Thanks Thumbs Up
Post #415218 24th Nov 2016 10:43pm
kbald
You should start off with something like meguiars ultimate compound to see if at gets rid of the swirls etc and if not work your way to a more agelessive cutting compound like farecla g10 or G3 so you don't do any damage that does need a pro to remove! Also perhaps a dual action polisher rather than a straight buffer as there is more room for error that way!! Once you get it to where you want it then a good quality polish and wax will protect it and make it shine.
You can get ceramic coatings to give some protection that supposed to last for years but whether it does or not remains to be seen. Some can be bought in the bay for about £50 or so!
Will give you a great sense of satisfaction doing it yourself and once you have the kit you can keep doing it!
Post #415223 24th Nov 2016 10:53pm
Mostly what mzplcg said, although I just used what I had in, 2,500 wet and dry, wet... stay well away from panel edges and swage lines then I had some Farecla G3 rubbing compound, then "T" cut and finally Meguiars fine polishing compound and finally Meguiars polish.....
If you use a MOP stay well away from the edges and use water, makes a right mess, don't get the panel too hot by keeping the MOP still.. move it all the time... Get a nice soft foam pad on the MOP...
If you're not careful you will burn the paint or wear through it on edges, but you have to be brutal to do it on paint that is a few years old...
Have fun.... Thumbs Up Pete
Post #415224 24th Nov 2016 10:53pm
alistairh
Thanks for that buddy! Never actually knew this process existed! My body works ok but could be better..i was resigned for putting the fatty into a body shop ..i will read up on it and give it a bash when the weather improves...fattys covered in 2 inches of ice just now so probably July Laughing
Post #415229 24th Nov 2016 11:18pm
Markjohns1
Had the same problem found it on you tube ,and restoreFX car care.looks too good to be true but have been assured a guarantee and after speaking to him again today informed can apply any further after market cleansers polishers and waxs although will not be required Full fat 4.2 Sc
Porsche cayenne
Tvr tuscan mk1
Bmw mini cooper
Post #415301 25th Nov 2016 1:01pm
builder1966
looks too good to be true I feel petes way is better or a really good detailer I had a rolls Royce done cost £500 don't tell her in doors and its superb now
Post #415307 25th Nov 2016 1:38pm
