![]() | Home > General > how deep is safely waded through? |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Britains longest Ford |
sorry I couldn't find a ffat but just wanted to let people know there were fords like this in Britain yu can drive down ! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Not sure about the L322 but the P38 was fairly impressive. Once drove (slowly) into a long ditch where the standing water came up to just beneath the bonnet. The water came up over the windscreen at some points whilst moving along. Never had a problem - got through to the end some 100m later and dry feet - no water had got in through the doors either!! |
cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 ![]() |
Incorrect good sir. 19.5 inches is for the 2003-2005. 06-09 can wade up to 27" The issue really is the traction if you can create a good bow wave and keep movement you can go maybe 3 feet or so. I've driven thru 30" or so. OffRoadRover.com An American Western Range Rover Off Road Blog |
That video reminds me why I drive Range Rovers and not Defenders... *shudders* |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 794 ![]() ![]() ![]() |
Here's my contribution on the way to work this week. A complete amateur I know |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
My contribution of what happens when the rear end decides to be buoyant and you hit a a rock with the front wheel and lose all momentum.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
As a very very simple rule, I go by the top edge of the alloy wheel as a suitable depth. That way, you're gauging depth on what is actually touching the ground, and not the bodywork. If you're maintaining momentum, then it should be fine at that depth. V8 or else ... |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1120 ![]() ![]() |
Do you take the spare wheel out and roll it through as a measure to check? letters not necessarily in the right order |
That's what venture cam must be for. I've still yet to find a use for the thing. Current
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
In the recent bad weather, came across a flooded stretch of road, with a 66 plate BMW X5 being towed out by a 90.
No, i tell the wife to get out and look for me. She has tons of wellies that clutter the hallway ![]() ![]() |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
What was in the LR in the vid? Sounds like the driver and passenger were wearing suits of armour or at the very least going to a saucepan collectors convention with 50 or 60 of their own rolling loose in the back.... QUID FACIUM TIBI
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
that noise may have been his recovery gear and jack kit. But then again the defenders and series LR's are much less refined than the fatties. |
