Home > Technical (L322) > Rear Brake Pads
tnysctt
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Rear Brake Pads
hello all just a quick question is there anything untoward in changing the rear brake pads on a 2005 TD6 or are the like most cars and require the piston screwing back in cheers
Post #415671 28th Nov 2016 9:06am
The handbrake is a drum inside the disc, so the calipers work the same as front ones, just use a G clamp to push the piston back... easy peasy...
I'd check the handbrake shoes as well, they tend to delaminate over time and can get stuck in the drum and overheat...
Plus the shoes are secured to the backplate and it tends to rust out.... Thumbs Up Pete
-Click here for Thread-
Post #415683 28th Nov 2016 10:42am
tnysctt
thats great thanks for the info cheers Thumbs Up
Post #415684 28th Nov 2016 11:00am
