|  | Home > Technical (L322) > maybe being a bit paranoid but..... |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | If it were me I wouldn't have left an engine idling for an hour, it doesn't do them any good. take it for a blast along the motorway and see how it is after that | ||
|  28th Nov 2016 4:14pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      |
|  28th Nov 2016 4:19pm |
| RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187      | With it sitting on idle the water vapour has probably pooled in the exhaust - a blip of the throttle will blow it out as steam .. as 47p2 suggests get it warm with a blast then see what it does
|  28th Nov 2016 4:34pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | Just had her out for a good hour around the bipass..all good now...what I did notice before I set off was a sound of water inside the exhaust back box..as you say its been steam! The noise must have been the steam being forced out causing panic within   | ||
|  28th Nov 2016 6:21pm |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035      | Expect on cold mornings, to have steam out the exhaust. It re-enters as you car cools down. And it reboiled out etc.
|  28th Nov 2016 7:04pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | Thanks for input...seems to have been a huge build up of water in the backbox..very pronounced sound in fact! Never realised so much would build up in an hour if I'm honest...there was so much that when i blipped the pedal the noise it caused sounded like some sort of backfire...I'm quite relieved now..  | ||
|  28th Nov 2016 7:23pm |
| Posting Rules
 Will give it a bash now..honestly never knew that leaving it idling would cause an issue..only left it on to bleed air from system after topping up antifreeze...smokes not excessive but I haven't noticed it before tbh...
 Will give it a bash now..honestly never knew that leaving it idling would cause an issue..only left it on to bleed air from system after topping up antifreeze...smokes not excessive but I haven't noticed it before tbh... Only thing that worry's me is the car sat in my garage for a few months whilst I was working on it..i had it idling 2/3 times a week during that time..could I have caused damage? Back box is probably rusted inside so lesson learned..cheers guys
