![]() | Home > Technical (L322) > remote FBH fob operation? |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
Can anyone clarify the operating parameters of the FBH remote on my 2011 tdv8
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367 ![]() ![]() |
If I remember right it will try to maintain 16°C internal ambient temp so will activate the burner if required.
Cheers Andy, so i am guessing it will need to be considerably colder than 16 before the fbh fires ? |
The FBH itself fires at 5 degrees I recall. Above that it will vent the car rather than heat it. |
thanks guys, guess i will need to wait a couple of months to see if it works then |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Any progress on this?
Have you tried re syncing the remote?
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
How does one disconnect power from the receiver please? Think I might have the same issue.. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
In the 2011MY, FBH fires at 15 degrees or below. Not 5 as posted above. |
Thanks for that!☺ |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
TomCobbly is right.
Well mine now works |
