![]() | Home > Maintenance & Mods (L322) > Axle oil |
do you mean differential oil.....anything on that? ... - .- -.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 840 ![]() ![]() |
No. I mean axle oil.
I am looking at item numbered 28. Renew front and rear axle fluid every 10 years. There are other entries 25 and 27 for differential fluids.... |
.front and rear diff oil, auto box oil, and transfer box oil but can't remember anyone on the forum changing their axle oil.. ... - .- -.
Me neither.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
There is no axle fluid because there is no axle, you have differentials and propshaft/driveshafts attached to the differential (the CV joints of which will be lubricated by grease and I've never known that as a service item, just replaced when the CV is changed).
thanks for that info Colin. |
Thank you Weejock.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
probably a left over from the P38 and classic which did have live axles. Can confirm that the only fluids needing changed are
