![]() | Home > Technical (L322) > To tint or not to tint |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
The lower ambient light levels inside the car and the lower light levels from headlights behind you will affect the interior mirror auto-dimming, and the door mirrors are controlled by the interior mirror over the LIN bus, so yes in short. The sensor is in the interior rear view mirror. Are you sure the doors have the electrochromatic glass? I thought it was only on Vogue SE and A/B. Easy to tell as there's 4 wires on the dimming ones and only 2 on the non dimming.
| Steve67 Member Since: 22 Nov 2016 Location: Essex Posts: 18
The door mirrors definitely change to a blue ish colour when bright lights hit them. Maybe it was an option at the time. Don't want to affect radio reception. Thanks for that |
OK, if you look below, the bit circled in yellow in the light sensor. When headlights shine through your back window and hit it the auto-dimming operates. This one sensor controls all 3 mirrors via the LIN bus
| hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294
But if the tint is cutting down the light from a car following to the extent that the auto dim won't operate then it propably doesn't need to dim the mirrors anyway, making the system redundant?, if you know what I mean.
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
Honestly doesn't make a blind bit of difference, I have heavy factory tints to the rear and my electrochromatic thingys work a treat. |
| XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995
same here... All my spelling errorz are belong to me!
The cars with factory tints may be calibrated differently. My current car has factory tints and is fine. A previous one came with aftermarket tints and it stopped the auto dim function form working. I removed the film and all was well again. |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I used to use proper custom fit blinds in the rear of my td6 and thought they were better as you could take them out in the winter etc.....
| builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299
those blinds look great it says pack size 8 is that for the tailgate as well ? |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
If the kids/family in the rear seats are ugly tint, if not then leave them clear |
The shades are for the lot.... the rear window is 2 pieces making 8....
| Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354
I have tints, good fitting so assume factory fit.
