![]() | Home > Technical (L322) > vogue central locking faulty....not the key! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Usually it's the key, not the FF, what makes you think it's the FF...??? Pete
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Based on past experiences, it could be the car but I think the L322 works slightly differently, hard to tell without it in front of me.
billsmith737 Member Since: 03 Dec 2016 Location: Bradford Posts: 41 ![]() ![]() ![]() |
i took the key in for repair, he tested it and it was sending the signal fine.... |
it registers the key being put in and taken out fine, if it was stuck wouldnt it beep all the time telling you youd left the key in?? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
I wonder whether the problem might be with rear door locks being sticky, I had that problem with one of mine. Only Range Rovers since 1988 |
They do sometimes lose the sync with the car, maybe reprogramming them would help....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
There is a way to do it, I agree with Pete it sounds like the key has lost sync.
ALL sorted now guys.....many many attemps at the re set procedure finally paid off!!
