![]() | Home > Technical (L322) > DREADED FBH |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi folks
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
This will help diagnose the problem http://www.the75andztclub.co.uk/forum/showthread.php?t=71982 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
HI graeme
hi folks
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
Bob the little aluminium finned radiator is the fuel cooler.
hi john
The fuel pump for the FBH is located in one of the most inaccessible |
ouch that sounds a |
Pretty certain the answer is NO |
Drawing from RAVE on location of pump
OK. well i will hav a look about popping the wheel arch cover off etc, i expect, looking at the posts, it is probably the PCB at fault, so hopefully it all comes out wwithout too much trouble
hi folks, ok i have decided i would rather have the FBH up and running than not, even if it does not get a lot of use;
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 124 ![]() ![]() ![]() |
You might find this file in Wiki very useful. Reading it I note that the fuel pump doesn't start running until 30 seconds into the start up sequence. I'm guessing if the glow plug has failed and the system fails to detect a flame then the fuel pump will be shut off.
HI TC
