![]() | Home > Technical (L322) > How to Find Top Dead Center TDV8 |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Ok lads.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1405 ![]() ![]() |
Did you move the fuel injection pump at all during the rebuild if so did you retime it to the engine
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hiya
I don't think it's the fuel injection pump. It can only fit on one way and as you said yourself it ran perfect for a few miles.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Start either easy stuff, check all the fuses. I agree it sounds fuel related. If a sensor somewhere is not reading right the ECU won't deliver fuel. Again check the easy to access sensors and connectors first eg MAFs next to air filter.
I have an IID tool but it's paired to my old Discovery. I must get it paired to the RR tomorrow. That might shed more light on the situation.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Do you get fuel at the filter? Can you crack one of the pipes off and turn it over? If you're not getting fuel there then perhaps the lift pump in the tank? Ed |
Yes. There is fuel at the filter! I wonder would the fact that the fuel is old be making a difference. It's from April? |
What's the temperature like?
You could be on to something. But surly the fact that she is pumping fuel out the lines it would be OK? There is approxmetely half a tank in it, should I add new fuel?
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
It's 7 - 12 degrees tomorrow? That is hardly too cold??
what were the temps today though and last night? Current
Some fuel may be coming through but not enough. The Series started and ran fine only until you floored it or went up hill.
