Home > Maintenance & Mods (L322) > Definitive answer please, where are the heated front screen
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Morning everyone.
Can anyone tell me where I can locate the relays for the heated front screen please.
I've checked fuses and theyre ok.
Cheers
Jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #416704 5th Dec 2016 8:02am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
There's only one and it's located behind the passengers side dash panel.
Open the passenger side front door and it's the small triangular shaped panel at the end of the dash, it just prises out and you should see two relays, the windscreen relay is the one that's closest to the small cubby hole.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #416715 5th Dec 2016 10:38am
jakebullet64
Hi UK Marine,
many thanks for your reply.
cheers
jake 2003 Range Rover Vogue 4.4 on Gas
Post #416778 5th Dec 2016 8:14pm
UK Marine
No problem Jake, hope you get it sorted Thumbs Up ______________________________
Simon
Post #416845 6th Dec 2016 11:03am
Has the screen been replaced at all ?
Mines an L405 so might be different
When mine was done, they connected it incorrectly - apparently there is a heater just for the wiper area and another for the whole screen - and the connectors are the same. When they came back out, it was a 10 min job to resolve.
The connectors are in the bottom corners - accessed by removing the internal pillar covers. The pillar covers have a badge on them, there is a screw behind the badge to remove them.
Separate connectors for each side - not sure if thats the same for other parts of the wiring or not.
Post #416851 6th Dec 2016 12:01pm
