Home > Technical (L322) > The confusion deepens over my Sidelight bulb
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
After more study I am even more confused. The online manual definitely says the front sidelight is a bayonet fitting but the drawing is very inconclusive (it could show anything). Online suppliers go for the 501 5w5 push fit (ive got some of those) and i was thinking of going the led route, but i have had trouble in the past on other vehicles with short lifetimes on these... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #416931 6th Dec 2016 9:30pm
Well I bought some 99p eBay specials, been in over two years, still work fine...
They were the push fit W5W ones, defo not bayonet....
The cold bulb monitoring (which you can't turn off on the sidelights) makes them flash 5 times each every time you start up, no great issue though...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #416944 6th Dec 2016 11:11pm
Spelunker
Thanks - I think it most likely that mine has pushfit. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #416947 6th Dec 2016 11:18pm
holidaychicken
i have had these in my sidelights for a couple of years, error free as well so no dash warning
http://www.ebay.co.uk/itm/RANGE-ROVER-VOGU...SwHJhXMk1v
Post #416952 6th Dec 2016 11:33pm
When you take the sidelight out, don't drop the big white nut which is tight to get to on the drivers side, if you drop it you have to take the undershield off to get it back... ask me how I know... Rolling Eyes Rolling Eyes
Another advantage of my new alloy guard, it's not as wide as the plastic, mind you with hands the size of a plate I drilled a hole in my white nuts (ooooh matron...!!!) and strung then up with a cord (this is getting silly)
So make sure you don't drop your nuts... Exclamation Exclamation Exclamation Pete
Post #416953 6th Dec 2016 11:34pm
Shocked Shocked £16 for two bulbs.... I've been buying them for years, cheap and expensive bulbs, and I have to say just get the cheapest you can off ebay for all LED bulbs, they all seem to come from the same place and the chances of premature failure has no relation to the price paid... Thumbs Up Pete
Post #416956 6th Dec 2016 11:38pm
holidaychicken
I'm sure that is true but they need to be canbus type and I bought cheap numberplate LED lights and they overheated and nearly set fire to my RR. They also made my LCM do some crazy things which could have been expensive shorting that out.
I have had my sidelight bulbs so long they must have come down a lot in price
Post #417228 9th Dec 2016 8:17am
supershuttle
I swapped mine on an earlier RR for LEDs, they flashed on start up, but no other problems and they were a delightful shade of blue. I think I got 'em of eBay, they can't have been that difficult to swap as I did it myself without problem. At the time mine was a 2007 and IIRC they were just 501s.
As for overheating I didn't think LEDs did that sort of thing, mine didn't anyway. Geoff
Post #417229 9th Dec 2016 8:49am
Spelunker
Sorted and surprise surprise the online manual got it wrong... QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #417431 10th Dec 2016 9:42pm
alistairh
Just changed mine to led..looks so much better without the yellow tinge..has anybody sourced ones for the fog lights yet?
Post #417903 14th Dec 2016 5:41pm
