![]() | Home > Technical (L322) > Rolling Screen? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
You say that the Nav unit has been checked. By that I assume the unit in the boot. I would suggest the next stage is to access the head unit to check the connections there.
Six-cylinder Member Since: 29 Dec 2010 Location: Buckingham Posts: 13 ![]() ![]() |
The rear wiring has been checked and the sat nav DVD has been substituted with one from a working car and now I have replaced it with a s/h unit reputed to have been checked.
If it is defective or has bad connections. John
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8113 ![]() ![]() ![]() |
![]() If 2 'specialists' have failed with the car in front of them, it's going to be hard to advise remotely.... It's a process of elimination - so unless you have access to a good car - and can swap your components into that one, one at a time, to prove they all work, I can't offer a better solution. Therefore, I agree with Weegie - if you're happy that all the units in the boot area are good and all the connections are firmly in place, then you will have to tackle the head unit itself as there isn't really anything else to try..... |
Electrical re-boot as advised on this thread ? |
It had a new battery while at Cowley and Co and a new battery lead while at EH Douglas. |
