![]() | Home > In Car Electronics (L322) > Which BT module do I need? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
bluetooth module has been removed.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Cheers, thats what I figured had happened.
Imo if you have no module currently going straight to the latest one as fitted in the 2010 disco4/res/fullfat is he best way to go 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35737 ![]() ![]() |
theres a list of BT module numbers in the wiki .. ... - .- -.
Thanks Stan, I have looked at that but assumed it was relevant to the replacement/upgrade of the pre MOST systems as it was referenced from a lot of these threads.
LR025842 is the part you need. Current
Thanks Andy,
If you go through Wiggs there is no surcharge. You just buy the unit and he gives you a little cable to power it. Think it's about £240ish unless they've gone up.
Just thought I would post an update for anyone else looking at this.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Thanks for the info MM.
Jono843 Member Since: 16 Jan 2017 Location: Mansfield Posts: 3 ![]() ![]() ![]() |
Hi, sorry to hijack the post.
Do you have to redo the 2121 every time you enter the car?.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Jono, As Greg says, I think that you need to reflash the BT module. Needs something like the iiD tool to do it. John
Hi gregdav and weegie, thanks for your reply. Yes I do have to enter 2121 every time I sync and there is no phonebook/contacts. It will connect fine but the clarity of sound in the cab is very muffled and inaudible. I've priced up the iid module and nearly shat myself lol I understand that wiggs does a Bluetooth exchange but I'm not sure if this upgrade will cure the sound issue. Iid module may cure this but I can't afford to buy one unfortunately. Is there anyone out there who can do this for a fee??? I can travel |
