Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 18 of 22 <123 ... 171819 202122>
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
dognero wrote:
Ordered 4 of these and see what they are like.
Ordered from where, anddn how much please?
Post #417114 8th Dec 2016 12:55pm
loads on ebay.. Thumbs Up ... - .- -.
Post #417133 8th Dec 2016 2:29pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Found the add, might invest in some myself, cant be any worse than std lights.
http://www.ebay.co.uk/itm/T10-501-W5W-BA9S...1933722852
Post #417136 8th Dec 2016 2:36pm
rar110
Thanks. I'll try to change the CCF. ______________________________
Post #417197 8th Dec 2016 9:26pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Bulbs on the right...Ones on the left are sidelights!
Installed these the other day. Definitely an improvement, but not day and night. You don't have to butcher the light housing, they just fit and you can't see these bulbs through the lense in the day time. Perfect for most!
http://www.ebay.co.uk/itm/301877126069?_tr...EBIDX%3AIT Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #417239 9th Dec 2016 11:37am
Strider
JPHC,
Like the idea of not hacking reversing light holders about, just ordered a pair Thumbs Up .
Post #417259 9th Dec 2016 3:16pm
Strider
Bulbs arrived, fitted this morning, started car, selected reverse, Bong "check reverse lights" displayed, soooo
they DO create a fault on the fatty (07 facelift 4.2 Supercharged) Big Cry .
Spoke to the seller, were very apologetic and are issuing a refund today, said to keep the bulbs. Interested to see if anyone else has same problem.
Post #417875 14th Dec 2016 2:29pm
JPHC
Strider, I was a little disappointed to learn that although they are advertised as 'Error Free', there still errored on my 07 SC.
I just turned off hot and cold bulb monitoring for the reverse lights with my IIDTool.
This way the car doesnt check the bulbs, so doesnt error. Not ideal but will do as its very easy to notice if one blows (Although unlikely) because you will see on the reversing camera at night. Also i much prefer them over the normal bulbs, so worth the small sacrifice!
Cheers, Jordan
'56 SC 4.2 ‘16-‘18
Post #417877 14th Dec 2016 2:34pm
Strider
Hi Jord,
Thanks for your reply, it is a fix, just annoyed bulb doesnt do what it says on the tin.
Cheers
Peter
Post #417878 14th Dec 2016 2:40pm
miggit
Shocked I'm surprised to hear that the bulbs are monitored full stop.. the 2011 ffrr that I did for Cavalier, weren't canbus and didn't throw any faults... but they were 2 x 6 watt panels in each light... obviously enough load not to cause a fault.. So that's another vote for splitting the lens and going bigger Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #417950 15th Dec 2016 12:16am
psgk
I also bought a set of these on the basis of JPHC's posted information. It looks as if the Auction Details have been updated to indicate that they may throw up bulb failure errors so no chance now of a refund.
I don't have a IIDTool to disable the bulb failure warning system so I'm sticking with the uprated standard type bulbs I obtained from Hungary Peter Kemp
Chelmsford
UNITED KINGDOM
Post #417959 15th Dec 2016 2:43am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Did you check to see if the bulbs actually illuminated, wrong polarity will cause them not to light and cause the error. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #417969 15th Dec 2016 9:12am
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
babagee wrote:
Bluegreygreen Rangie wrote:
They look pretty darn good
Has anyone seen or used these http://www.ebay.com.au/itm/360944738589?ul_noapp=true
Dave
I've fitted these and the reversing lightt output is very good and a great improvement on standard output
Mine also flash in time with the indicators but led red - a bit to policey (?) but have been through 2 MOTs with no issues
Also with upgraded bulbs to original lamps, with no error bongs
Post #418006 15th Dec 2016 2:22pm
Strider
Hi Wayneg,
"Did you check to see if the bulbs actually illuminated, wrong polarity will cause them not to light and cause the error".
Yes I did check, they were very bright, regarding the fitting, they will only fit one way as one of the location pins is offset (when bulb is viewed end on ie the pins are not in line), the bulb has one central +contact the body is the return.
Cheers
Peter
Post #418011 15th Dec 2016 2:44pm
miggit
babagee, in reply to your last post...... I did Quote you but that seems to have evaporated Shocked
That is because you have exceeded 6 watts per side, the LCM thinks that you have a normal functioning bulb and all is OK Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #418028 15th Dec 2016 4:22pm
