![]() | Home > Technical (L322) > alarm reset L 322 |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
First things to try:
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I've done the same...dead battery.opened door with key and alarm sounds but you can't turn key in ignition...as above charging battery and retry! I found the key not turning was simply because there was no power...once batterys charged it car gets a jump start it should turn .. |
| gillech Member Since: 03 Nov 2015 Location: montreux Posts: 18
thank you for your help.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
You can charge the battery connected to the car BUT the point of taking off both connectors and touching them together, as described above, is to reset the system. John
| All times are GMT |
