![]() | Home > Wheels & Tyres > Stowing the Spare - 255/55-20 |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
Yes. Mine has this size and i have a full size spare 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Yes it does and it is made a lot easier with the webbing strap thingy.
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
'Webbing strap thingy' ... |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Think he means the gizmo on the earlier ones that would lift the spare out of the cradle for ease of access. Unlike the later ones that you get a hernia lifting out. 2009 Vogue TDV8 Nara Bronze
mogman50 Member Since: 29 Sep 2014 Location: Settle Posts: 37 ![]() ![]() ![]() |
Well I must be doing something wrong then.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
I have a 255/55R20 spare, fully inflated. I wouldn't try to lift it out without the lifting rig that uses the lower tailgate to do the work. Ron B. VK2OTC
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
My 255/55/20 Pirelli scorpion fits in inflated, the diameter should be 55% of 255mm x 2 + 20" but I think the grabber has a deeper tread so maybe the calculated diameter is based on a bald tyre?
Hang on, can't edit my post from my phone, I think I might have 255/50/20, will check |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
My oversized 20" Scorpion'd spare fits too, although is a bit tighter than when on standard tyres. 2007 Vogue TDV8 with 255/55/20's fitted |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
255/55-20 scorpion just fits when fully inflated but it is a bit tight. The correct size 255/50-20 fits better as it is 1" diameter smaller. Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
Elvis1 Member Since: 19 Dec 2016 Location: Illinois Posts: 2 ![]() ![]() ![]() |
I just fit a fully inflated 265/50-20 Nitto Terra Grappler G2 in the spare tire well of my '08sc without issue. |
