![]() | Home > Technical (L322) > Intermittent wipers that arnt!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Have you got a rain sensor? .
billsmith737 Member Since: 03 Dec 2016 Location: Bradford Posts: 41 ![]() ![]() ![]() |
no |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
I would suspect rain sensor.
Hi, no, no sensor and the rain was very light, just a bit of drizzle realy hence why i just wanted a slow wipe as i ducked through traffic..... |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Im sure rain sensitive wipers were standard on the vogue! You need to put them into intermittent setting after the car is started for them to work as if you start with intermittent there is a fail safe incase of a frosty windscreen ruining the wiper blades. Try turning them on then pour water over the windscreen from a hose and see if they come on. |
The only way it could not have rain sensing wipers is if it has had a new windscreen and the wrong one was fitted without the blue window but that would still leave the small problem of the sensor still being there somewhere , is the windscreen dirty at all up at the blacked out bit around your mirror ? 2008 MY Supercharged
Aaahhh.....Ok, I was looking for a separate sensor, there is an oblong within the rear view mirror mount that can only be seen from outside...is that it?
I think the windscreen may have a sensor in too. The rain sensor is random but is controlled by the amount of rain and heaviness so shouldn't be a distraction in fact should be the opposite and take the rain away without you thinking about it.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The sensor is behind the rearview mirror.. as you move the adjustment lever / dial on the wiper stalk it increases or decreases the sensitivity of the auto wipers.. when the lever is at 12 o'clock then it's at it's least sensitive |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Mines was doing the same..easy to check..pull the connection to the sensor then try wipers..i ended up fixing mine by pulling the fuse and I reset the lot.. |
Daft question maybe....but what does the sensor look like?...where exactly is it? |
Its in the glass..basically behind the mirror.. |
Just looked on YouTube...there's a video (for a sport)...showing it, it is the black oblong I thought it was, I'll pull the covers off and see if there is an obvious issue.... |
like this ,
