Home > General > Gearbox gone pop.....
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Bought the car with 80kmiles on the clock and it had a tendency to go into gearbox protection mode after going 20 miles or so... Replaced hoses, rad, oil heat exchanger, hoses, dropped the sump, changed the oil and filter - problem sorted.
Until the day before yesterday.....
Went to pull away from a roundabout and it rev'd, then clunked, and pulled away as normal. Our roads are a disgrace so I assumed I'd been half sitting on ice but then it did it again a few minutes later Shocked Got to destination, the car cooled, got home, no issues.
So, it seems to only occur when the car is up to running temp. Took it to a mate who runs a local independent garage that specialises in Land Rover and he plugged into it to get "Gearbox Monitor Fault" or something along those lines.. After a couple of conversations, the symptoms are that the box is goosed.
So, I'm currently waiting for a refurbished gearbox Big Cry which will lighten my pocket significantly, at exactly the wrong time of the year.
I guess the fluid flush and filter change basically only delayed the inevitable....
DC
Post #41720 10th Dec 2010 12:38pm
thats really bad luck especially after all that hard work doing the oil change etc..could one of the replacement items have been faulty maybe.. ... - .- -.
Post #41723 10th Dec 2010 1:00pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
I feel your pain! Sad
Just had my box reconditioned - 80,000 miles is about the norm I'm told. You could look up RRPhil on "the other" forum - He was doing rebuilds a while back for people in the north east if I recall correctly. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #41763 10th Dec 2010 4:11pm
DeltaC
I think the oil change just delayed the demise... it was "its time".
I flushed it at least three times but from what the garage say, its just wear on friction parts that has caused the issue. If I could do without it for a while, I may be tempted to give RRPhil a try but I need the car.
Its the first time in years I haven't had a spare vehicle that I can use - I've got a 90 and a 110 waiting to re-chassis and its a tad slippy for the Hayabusa to come out Whistle
Post #41778 10th Dec 2010 7:54pm
