Home > Technical (L322) > What are the symptons of a faulty turbo to intercooler hose
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Just wondering what the symptoms are if the the hose from the turbo to to inter cooler has a small hole/leak?
Post #417839 14th Dec 2016 9:53am
Usually a whole lot of black smoke out of the exhaust on acceleration
Post #417840 14th Dec 2016 9:54am
lounge_on_wheels
thanks
Post #417844 14th Dec 2016 11:56am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Or hardening up or collapse to the touch
Post #417854 14th Dec 2016 12:40pm
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
i had a split hose yeaserday!!!
i noticed a slight odd noise, hard to hear tho....then she sudenly went into limp mode and gave me an engine fault message!.............same spot two days apart.
The indy next door to my work read the code, first time they said at was the turbo acctuator.....big money!!
second time it came out as an air flow error, the hose had a 2" rip in it!
had both hoses changed there and then, £109......feels and sounds alot better.
there was no smoke at all and no noticable loss of power either tho!!....it just showed up when i was going up a steep hill at a particular speed, throttle position, rev range etc.....if i booted it (the day inbertween the fault showing) it was fine!!
Post #418278 17th Dec 2016 1:56pm
