Home > Technical (L322) > Emergency stop.
Clivefog
Emergency stop.
Just bought the Christmas tree, slid it in over the boot cover and into the cabin, blunt end hanging in the air.
Of we set and some mindless child decides to ride across the road at a pedestrian crossing.
Foot hard on the big pedal and I come to a halt. Xmas tree shoots forward and stops on the wife's arm, heavily bruised but I digress.
Front offside wheel locks up and skids on the anti skid surface! Went out again on dry and clear bit of road, did a few nose in the ground stops and only left two "you can just about see them" black marks.
Need I worry?
Post #418198 16th Dec 2016 8:49pm
Did you get a pulsing effect from the brake pedal..??
If you did the ABS has cut in and worked, the wheel has to skid before the system works so you can still get a lock up, it also slows the wheels to less rotational speed than speed across the ground so you will leave skid marks... Thumbs Up Pete
Post #418202 16th Dec 2016 9:28pm
What Pete said Thumbs Up you can't fail to notice the ABS pump cutting in. Feels like a grinding graunching sensation, which you can feel through the pedal. There is nothing that can't be fixed with a hammer😜😜
Post #418203 16th Dec 2016 9:31pm
Clivefog
Thanks guys.
Yes the pulsating feel and squeaks from the tyres was evident when I did my testing.
Not sure about the incident though I suspect the boy had to change his underwear!
Had I been in my old Toyota MPV I'd be talking to police right now.
No doubt I pressed the peddle a lot harder at the time and I was not recording all the cars feedback, rather the bike and my bumper.
It stopped straight and true so any thoughts of something wrong are put to bed.
Merry Christmas
( oh the wife, just something else for her to moan about - no change).
Post #418283 17th Dec 2016 2:39pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Remember that all abs braking systems have to lock up at some point - you don't stop otherwise Rolling with laughter
Simon
Post #418284 17th Dec 2016 2:41pm
Don't forget you have EBA which senses when you brake fast and takes over for you, it is amasing how soon these big beasts come to rest when it engages.... Thumbs Up
From the handbook
Emergency brake assist (EBA)
If the brake pedal is depressed rapidly, EBA automatically boosts the braking force to a maximum and thus helps to stop the vehicle in the shortest possible distance, when a full brake application is made. Also, if the driver brakes more slowly, but with sufficient brake pressure to activate ABS on both front wheels, the system automatically increases the braking force so that all four wheels are in ABS control, optimising the performance of the ABS system. Pressure should be maintained on the brake pedal during the entire brake application. If the brake pedal is released, EBA will cease operation.
You also have CBC and EBD Thumbs Up Thumbs Up Pete
Post #418291 17th Dec 2016 4:24pm
Clivefog
One day I will read the manual.
I think I was in shock yesterday because it was that close, ok now and functioning on both brain cells. Tree up and full of stuff, lights working,
For anyone who has to do a quick stop, yes they do!
Post #418317 17th Dec 2016 6:38pm
