Home > Technical (L322) > Really bad burnt smell HELP!!!
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi again,,
My 03 td6 is gone yesterday,felt bad;but 06 td6 is burning oil or smt.
Cabin takes smell also especially when reversing.
Any tips_?
Post #418305 17th Dec 2016 5:32pm
rar110
I think I've read the GM transmission can make a smell when it fails. ______________________________
Post #418354 17th Dec 2016 9:27pm
umitbat
Transmission is new and Works fine.
Post #418356 17th Dec 2016 9:48pm
not being with the vehicle its difficult to diagnose something like this ..it could be a blown gasket to a racoon trapped under the exhaust but i hope you get it sorted.. ... - .- -.
Post #418361 17th Dec 2016 10:55pm
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
it might sound daft but have you checked to see if a poly bag has got stuck on the exhaust Shocked ...it may be that it smell worse when reversing due to the change in air flow........i know....its a mad suggestion...but it happened to me many years ago....just worth a look.
Without smelling it its very hard to guess tho.
Post #418367 17th Dec 2016 11:15pm
jambo27
Another random sugesstion - sticking brake caliper. Not often noticed in the cabin though and the smell is very distinct smell - think the smell from welding and its pretty similar. 2008 TDV8
Post #418446 18th Dec 2016 1:11pm
Or possibly an oil leak dripping on the exhaust... Pete
Post #418450 18th Dec 2016 1:28pm
umitbat
A service guy said webasto??Do i have one?A heater?
It is better when warm.Nowadays very cold here.
Post #418502 18th Dec 2016 6:17pm
did they have td6's in the states?? i thought it was all petrols.. ... - .- -.
Post #418505 18th Dec 2016 6:26pm
umitbat
not states wrong info
Post #418506 18th Dec 2016 6:47pm
Is you dipstick in place correctly. If the oil separator thingy gets clogged it can create crankcase pressure that blows the dipstick out and then oil gets sprayed around the engine bay.
Could also be the FBH exhaust fumes, when mine worked I got a smell on start up. .
Post #418552 18th Dec 2016 10:29pm
umitbat
sorry what is fbh??
Post #418563 18th Dec 2016 11:28pm
Apologies
FBH - Fuel Burning Heater - the Webasto thing your service guy muttered about. (The FBH is made by Webasto)
Worth getting codes checked, maybe it is working too well!! .
Post #418572 19th Dec 2016 1:06am
