Home > Technical (L322) > Normal Height only then red triangle/ Don't exceed 30mph?
pld118
Well, the wee LR man is booked in to come and plug his diagnostic tool into the car tomorrow morning before, I suspect, an inevitable call for a low loader to take it to an LR dealer!
Do you get a courtesy car in these situations???
Post #418509 18th Dec 2016 6:59pm
pld118
Diagnosed as a problem with the suspension compressor apparently. LR assist diagnosed it on the driveway and due to return tomorrow to replace it under warranty in situ.
Post #418718 19th Dec 2016 10:36pm
Did they sort it Ryan? There is nothing that can't be fixed with a hammer😜😜
Post #418844 20th Dec 2016 5:38pm
pld118
Apparently so Mark... New compressor and relay switch Thumbs Up
Post #418928 21st Dec 2016 12:07am
pld118
Having now read the LR report the fault codes were:
C1130-7A
C1A20-64
C1131-92
Post #419689 27th Dec 2016 11:07am
pld118
Mrs pld says the car seems to sit a little lower at the back since this recent warranty repair was done by LR assist on our driveway.
Sooo... Whilst the car is in at the MD for a couple of other minor 'keep on top if it' areas of work, they have been asked to check the suspension height out. They rang me late today and said they would have to let it settle for 48 hours and then measure the top of wheel to the top of arches to decide if it is within manufacturer's limits.
Is it me or does that smell like BS? Shocked
Post #429458 27th Feb 2017 8:40pm
Could be right, checking to see if it's dropping over time. Wouldn't necessarily see it after a couple of hours. There is nothing that can't be fixed with a hammer😜😜
Post #429519 28th Feb 2017 12:58pm
pld118
Car been returned to us... I can see that the rear arch is closer to the top of the wheel than the front... They obviously didn't have it long enough Laughing
Post #429548 28th Feb 2017 7:17pm
there should be a cm difference between the front and rears Ryan. ... - .- -.
Post #429560 28th Feb 2017 8:06pm
