![]() | Home > Maintenance & Mods (L322) > door cable |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Its a basturd , I did it by absolute blind luck, not much help sorry, but I feel your pain. At least you didn't fit a new cable wrongly which pinged off when the door shut and you then had to bend the door card to get the fecker off.. |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
Offer up the door card and make sure the inside handle is pushed in, then insert the black plastic end in and it should clip in,
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
| vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110
thank you thank you thank you |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
One of my pals has this problem with his ffrr.. turns out that it's the cable window regulator slipping, and the only fix is a new regulator... and according to my pal it's a rather involved job Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Changing regulator is not as bad as u think miggit. I did it myself and it took a coupla hours but then I am a complete numpty when it comes to things like this. But all good and all working fine. |
I just don't understand why the glass has to come out |
Because of the shape of the rear door (with the rear wheel arch curve) the glass cannot be lowered enough to fully clear the 2 retaining bolts - It covers one of the retaining points of the regulator if left in. You have to remove the glass to be able to get your Allen key/Torx thingy in. |
| All times are GMT |
