![]() | Home > Technical (L322) > TDV8 turning over but won't start |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Hey, Sorry to hear of your troubles! My TDv8 is doing the exact same thing, bar the low fuel pressure warning.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
I found when I put in the cheapest diesel I could find, it was a struggle sometimes to start.
StefanW Member Since: 10 Dec 2016 Location: Star Court Posts: 4 ![]() ![]() ![]() |
Update: Drove down to the workshop again today, cleared the codes yet again, re-bled the low pressure side again, verified that neither the fuel filter block nor the fuel cooler were blocked.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
I would not assume that the HPFP has failed as I expect its pressure to be ecu controlled. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Although with a low pressure fault and no pressure at the rail I think I'd be leaning towards a new pump, they are a common failure point... |
Turned out to be the HPF pump that had decided to call it quits...but not in the normal way...the pulley had come loose somehow, but I replaced the pump with the new as I had already sourced it. |
