![]() | Home > Technical (L322) > Don't get too cocky !!! |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
really worth doing the double battery conversion its in the wiki |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I have suffered similar, camping all weekend, tailgate open regularly/extended periods
Of course it's worth it. Most days ![]()
I did, with both my D3s. Both ended up with dual batteries.
Yes, he can take the pee, on the odd occasion. All the rest of the time you are in the Fatty, feeling fine and he's in a clattery Korean POS. As Churchill pointed out to his housekeeper when she chastised him for being drunk, "Yes, Madam, I am drunk, and you are ugly. But in the morning I shall be sober and you will still be ugly" So, stuff to do. LED conversion inside the car, all 83 million of the interior lights. With filament bulbs at 5 watts each it's like leaving a headlight on all the time. Dual battery conversion. It's in the WIKI and it gives another 60 or 70 amp hours of capacity. Use a 300 amp relay, fire it from a terminal which goes live when the engine is running and put an over-ride switch on it. If you ever get a low starting battery flick the switch, leave a couple of minutes and she will fire up fine. I trend to avoid split charge relays as they have diodes in usually and there is a voltage drop across a diode of at least 0.7 volts, 1.4 volts for a rectifier. Relays don't drop, they just connect. |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Just been out to the ff, and the |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8604 ![]() ![]() ![]() |
Get the CCF reprogrammed to not put all the interior lights on when the boot is open, they only stay on for 16mins with it open so you must have done it several times to reduce the battery voltage that far...
Negative
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
change every bulb to led ive done all my RR over the years and have had doors and tail gates open all day no issues |
Or simply turn off the interior lights.... |
