Home > Maintenance & Mods (L322) > battery drain
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
battery drain
been having trouble with battery drain over night Rolling Eyes after much reading im thinking hevac resistor as when i get in the car in the morning i can hear a fan noise coming from behind where the battery sits Shocked what do you think Question
Post #418640 19th Dec 2016 2:47pm
alistairh
Easy to check..either pull the fuse on the hevac system and observe ..you can also sit in the back seat,lock car and sit very still for 16 mins and listen for the wee fan behind the dash to stop..(think its a fan for an ecu)..also worth checking headlight wipers and motors...sat nav is easy to check as well..
Post #418641 19th Dec 2016 3:00pm
You don't have to lock the car and sit still in the back, get in the front, shut the door, don't put the key in or near the ignition and 16mins later it should switch off... Thumbs Up Pete
Post #418645 19th Dec 2016 3:25pm
alistairh
Haha I was sat like a complete plumb then Laughing Everytime I tried it in the front the alarm wouldn't set as a sensor under the seat must have sensed me..realised that then sat in the back like a statue...my neighbour was watching and thinks I've finally cracked...
Post #418646 19th Dec 2016 3:45pm
vmaxer
so something the wife can do while i have a brew Laughing ill get me camera out Whistle
Post #418771 20th Dec 2016 11:32am
alistairh
Laughing Laughing
Post #418773 20th Dec 2016 11:39am
vmaxer
morning, put the new resistor on xmas eve not used till i came to start this morning Twisted Evil Rolling Eyes bloody flat battery so back to the drawing board .the wife sat in it for 30 mins said she didn,t hear a thing ,light went of on gear selector no fans running Big Cry starting to wonder if the new battery is faulty or ideas plz.
Post #419692 27th Dec 2016 11:16am
miggit
Have you checked the left hand boot cubby box for water? When mine filled up it took out the DSP amp, which killed the radio and the battery in one go Big Cry Also the DVD Navi head unit has been known to empty the electricity overnight Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #419846 28th Dec 2016 2:35pm
vmaxer
nothing wet at back Smile next step utube Rolling Eyes
Post #419854 28th Dec 2016 4:24pm
alistairh
Do your headlight washers/wipers work ok? That's also a possibility! You can rule out fsr and sat nav so worth pulling their fuse and watching...after that its a matter of pulling fuses,checking earth connections ect and worth checking the possibility your battery's had it....
Post #419858 28th Dec 2016 6:03pm
vmaxer
beginning to think battery Rolling Eyes went to it this morning started no probs took it round the block pulled back on drive checked battery 11.8 new battery aswell Crying or Very sad checked with engine running 13.8 so its charging.
Post #420001 29th Dec 2016 3:05pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Next door has same problem with BMW X5. Did the usual checks to make sure alternator was putting charge across- Fine. Just got back from EuroPart with his battery which is 15 months old and on a 4 year warranty. Their tests show it to be holding a charge. So where to now. It only flattens on a random basis. As so many Range Rover and BMW X5 diesels have matching parts, is there a similar sequence for tracking down this problem ?
Post #420022 29th Dec 2016 5:15pm
CS
I don't know whether this applies to your car, but I have had two drains due to software faults, one to do with the fuel burning heater and the other with locking. In each case the LR Assistance technician said that he could not run a diagnostic test to find the problem as the battery needed to be fully charged first. As the battery was fully discharged in each case there also needed to be a test to see whether the battery was ruined by the experience or whether it would work after being recharged. So the car went off to the dealer and they charged the battery fully and ran the tests. In the first case the battery needed to be replaced, the second time it was OK.
So maybe getting the battery fully charged and running a diagnostic test might establish what is wrong, and also whether the battery can still be used, the one that I needed to replace was no more than 18 months old. Only Range Rovers since 1988
Post #420048 29th Dec 2016 6:54pm
DaveK
Thats why I used an intelligent charger to bring the battery up to full before submitting it to testing. Would have been so much easier if it had been naff but alas its ok so no easy route for my neighbour.
Post #420060 29th Dec 2016 7:31pm
CS
DaveK, just for the avoidance of doubt, what I was told was that the battery needed to be fully charged before the car could be interrogated on where the problem was, i.e. what was draining the battery, in addition to the separate test of the battery itself to see whether it would be OK once the problem that caused the drain had been fixed. Only Range Rovers since 1988
Post #420062 29th Dec 2016 7:41pm
