![]() | Home > Technical (L322) > Heated Washer Jets |
The RR was tested in temperatures much less than -13c. Have you checked to make sure they heat? Further Info: When working they should measure 27ohm - this was from the Disco3 so hopefully they are similar enough. ![]() |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I'm sure even if they heated, it wouldn't help the pipework behind it freezing .... Will check heated nozzles though. |
No but that will depend on what mix of screenwash you use. The Holt stuff is rated down to -16 and is about a fiver for 5L. Or Autoglym all season is rated to -40 if used neat but would work out very expensive. ![]() |
Expensive, tell me about it.... Last week I spent £15 (3 x 5ltrs) on screen wash, using it neat gets expensive!! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Given what these vehicles are capable of doing, you'd think a simple thing like cleaning the screen would be a piece of cake.
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
Noddy, consider buying replacements, mine have been fine since but I've also increased the concentration of screenwash to prevent freezing in the expansion tank. Hope I haven't jinxed myself now!! |
Have you checked to see if the washer jets are working yet before cussing it? ![]() |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I don't know why manufacturers haven't started adding heating elements in the washer bottle to prevent screen wash freezing. My mate has an old Volvo 360, the coolant reservoir sits on top of the washer bottle, I don't think his has ever really frozen up, quite an ingenious idea really. 2006 Mercedes CLS
Because god invented screenwash... ![]() |
touché young man 2006 Mercedes CLS
Aside from all this talk of exploding windshields, copper pipes, and other sillyness...
Nope. Only found out on the way to London. Prior to this, they worked ok. Will get the multimeter out tomorrow. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 ![]() ![]() ![]() |
had the same experience
Excellent DIY I would be interested in further reports as to its effectiveness...
