![]() | Home > Technical (L322) > Re Bosch recon alternator |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
can you fill your car profile in so we know what you have... ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8747 ![]() ![]() ![]() |
Something prevents the alternator putting out a charge for the first minute or so, to assist the engine to start, that's why there is a delay... Probably the BECM
Dave 67 Member Since: 11 Dec 2016 Location: Oxfordshire Posts: 34 ![]() ![]() ![]() |
It looks like I have but not populating I have just been back out to the car and it won't start and the battery voltage is now down at 9.2 volts!!thats in about an hour. What is making the revs rise and fall is this related to low battery voltage due to battery possibly not taking charge?? Or is the new alternator dragging the voltage down, it was fine on the first drive round the block none of these problems then all thises issues started after about 15 mins. 2004 4.4V8 Vogue BMW 330CD BMW523i Escort Mexico MK1 1974 airportable series 3 Last edited by Dave 67 on 18th Dec 2016 4:19pm. Edited 1 time in total |
Think I'd try removing the battery, (well, disconnect it anyway) fully charge it overnight and see what happens, low voltage can pull all sorts of problems and the voltage was low when you jumped it....
Battery already out of the car not sure why the voltage was still falling after car turned off, will see if I can borrow a charger do it over night.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I've just replaced my battery..prior to replacement my idle.was up and down and it would do it with anything under 1000rpm..thought I had a bad sensor somewhere then replaced the battery and it stopped it instantly..i think the car does it if voltage is too low..mine would drop from 12.5v to 9.5v in hours after a charge.... |
Chances are the battery is toast, a failing alternator is well known for taking the battery with it.. As I said, they hate low voltage, if the battery is toast it will lose voltage very quickly... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Battery on charge all night disconeccted at 6.15 this morning just checked with a multimeter at7.15 still sitting at about 13.1V.
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
i replaced last month at dealers and was replaced with 110ah 88 seems a lot to small |
The 110amp is for the diesels, yours will work fine for now, if you have to change it there is an argument that the additional few quid for the bigger one is worth it... |
So update!!
Just wanted to say thank you to the people who replied with advice, especially Haylands for his time and advice.
Always good to get an issue like this resolved even if it has cost some extra coolant |
Result, pleased you got to the bottom of it, that is rare to have a recon failure as they are tested by a real person... must have been a Friday one...!!!! Pete
