![]() | Home > Technical (L322) > coolant system querie.. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746 ![]() ![]() ![]() |
Personally I don't like that bleed screw, I always leave it well alone, it just seems to create air locks and problems, I always fill the system very slowly then leave it ticking over for 30mins with the main cap off and it pukes all the air out... Pete
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I tried it again tonight..only got a slight hiss from it so I'm a bit relieved...amazing how its stayed slightly pressurised for a few days after I last used it? The second I seen it spewing coolant I thought the worse.(as usual |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 834 ![]() ![]() ![]() |
It's usually a good sign to have a bit of pressure left in the system after a few days, it shows that the head gaskets for one aren't leaking.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
![]() ![]() ![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
@uk marine..thankyou...thats all I needed to hear..i was out with a torch very near on midnight running the fatty last night..coolant cap off looking for bubbles |
Goodness you do have Roverphobia - but then again we all do |
Is that in Egypt somewhere miggit? |
Yep, you lot have it bad.... |
