Home > General > 2010-12 MY buying advice
Page 2 of 5 <12345>
CS
I think EBA would be standard all models, adaptive cruise standard on VSE and AB, option on Vogue and WM. I'm not aware of blind spot monitoring before the 405, my 2012 WM does not have it anyway. Only Range Rovers since 1988
Post #419001 21st Dec 2016 1:59pm
cliff5.0sc
I found in my experience and through various interviews the 4.4 and 4.2 SC are generally more reliable than the 5.0 and 5.0 SC. The conclusion of my Range Rover Book: L322 Buyers Guide is that for 2010+ you should go with the 4.4 TDV8 for reliability.
The 2010+ have quite a bit of tech. I believe the 2010 SC (roughly equivalent to VSE) in the USA included the EBA, Radar Cruise Control, Blind Spot monitoring, surround view camera, and dynamic headlights, these options were later deleted from the SC spec as standard in 2011 and 2012 and introduced as an optional vision package in the USA. In the UK and USA all autobiographies have the vision package as standard afaik. OffRoadRover.com An American Western Range Rover Off Road Blog
Post #419085 21st Dec 2016 9:26pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
My 2010 vse has blind spot monitoring and virtually all the other goodies including electric locking rear diff, but no adaptive headlamps.
Ian
Post #419127 22nd Dec 2016 9:44am
giga1tr
Switzerland 2011 Range Rover Autobiography Black 4.4 V8 Barolo Black
I have my AB Black 4.4 MJ11 now a year and this is definitely one of the best cars I've ever driven.
It is for me, in terms of driving comfort and equipment, with nothing else comparable.
He still makes me smile every day and I have never regretted the purchase. Thumbs Up
Alain
Post #419247 23rd Dec 2016 8:00am
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
The one bad thing I'd say about my 09 MY10 rdv8 is the breaks are poor, I think they're Land Rover Ines rather than the bremo ones, some have them and some don't 2018 Suzuki Jimny 2003 written off
2016 Range Rover TDV8 MY10 current
2013 Range Rover TD6 2005
2012 Defender TDCI 2007
2010 Toyota Hilux 2003
2009 Audi TT 1.8T 225
2007 Suzuki SJ 413 with 1600 fitted
2006 Yamaha R6 2000 still have this
2006 Audi A3 1.8T 1999
2006 Defender TD5 1998
2005 Audi A3 1.6 1998
2004 Suzuki vitara 1994
2002 Proton 1500tripple valve 1991
Post #419248 23rd Dec 2016 8:19am
kooky_guy
Hi All,
It seems to me that the later models seem to have had a lot of what was once standard removed (ie RSE in the VSE), which seems a bit cheap considering the price of them when new! Still love them though.
Can someone confirm that the remote controlled FBH is still standard in the 2010 models? Or is it called Park Heating now? I'm a bit confused.
Is there any way of easily visually checking that the oil drain mod has been done?
Hopefully going to look at a couple over the Xmas break. 2010 4.4 TDV8 Vogue SE
Post #419257 23rd Dec 2016 9:19am
mjdronfield
My 2011 has RSE and remote heat. It has park heat too. I think park heat is when you can program the FBH to come on at a certain time, when the car is parked....
A dealer should be able to tell you if the drain mod has been done.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #419331 23rd Dec 2016 6:09pm
GraemeS
Australia
The revised drain has 2 pipes instead of the original 1 but it's difficult to see the bottom of the turbo.
Post #419398 24th Dec 2016 12:03am
Just to clarify things vis a vis Park heating and fuel burning heater , park heating is the function where residual heat from an already warm engine is used to operate the hvac system via the auxiliary coolant pump and is operated by simply pushing the Max button when stopped and the engine is off . Nothing to do with the thermotop fuel burning heater . 2008 MY Supercharged
Post #419413 24th Dec 2016 2:28am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
The turbo drain mod
I had the MY10 3.6 and currently have the MY11 4.4.
Never had a problem with the turbo drain on either. But could be the way I drive them.
The second turbo gets a regular work out.....
If the mod causes you sleepless nights then take it down to Craig to have it done.
That I haven't had mine done doesn't worry me in the slightest.
Post #419435 24th Dec 2016 11:30am
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Are the "secret" diagnostic screens still available in the '10MY vehicles and onwards and, if so, has the procedure for accessing then changed? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #422731 14th Jan 2017 4:14pm
GGDR
Hi guys, I am also trying to establish spec for MY2011 - Mainly what was standard and what was an option for Vogue vs Vogue SE, Autobiog. I've typed up a grid mainly showing the gadgets I really want.
I realise most things were an option so especially want to know any standard items.
Can anyone help populate my chart?
This is for UK spec cars.
Post #424148 21st Jan 2017 9:03pm
proser
Westie
The following are standard:
Front seats cooled
Rear Seats heated
Privacy Glass
Front Park Sensors - all have
Dual View
Xenons
FBH
Heated Steering Wheel Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #424165 21st Jan 2017 10:12pm
Vogue
Xenons - Standard, adaptive headlights option
Heated Rear Seats - Standard
Front Parking sensors - Standard
Hill Start Assist - Standard
Power fold mirrors - Standard
Heated Steering wheel - standard (or at least never seen one without)
sun roof - standard
Preheater - All diesels have the heater, I think the remote was optional though but both my vogues have had one.
I think most Vogues have most things, and work up from there. I have never found the Vogue lacking in spec. the only thing I may have wanted extra is adaptive cruise control, but i can live without it. RSE was never an issue as its to restrictive as to what you can do with it. 6 DVDs in a changer for a trip to the south of france is a waste of time, and you have to half empty the boot to swap the discs.......Ipads are a far better option Thumbs Up
Make a list of wants and needs.
i.e. need - 20" wheels Whistle
want - cooled seats. There is nothing that can't be fixed with a hammer😜😜
Post #424221 22nd Jan 2017 12:22pm
GGDR
Thanks guys for those updates.
Whilst on the hunt for my 2010/11 4.4, i came across one with 107k miles on it. It's got FSH but I had hoped to get one circa 80k
I will only do 6-8k per year.
Wondering what anyone thinks on mileage over the 100k mark?
Cheers
Post #424495 23rd Jan 2017 11:22pm
Page 2 of 5 <12345>
